Hi All,
Im new to the forum, been reading for a while.
Ive just baught my first home, and about to start decorating before moving in, before painting, there is one bit of DIY that i would like some advice / comments on.
I will be wall mounting a TV, i have baught the correct bracket, and the walls will hold the weight (there not plasterboard walls but proper brick and mortor walls).
Now i dont want to see the cables comming from it, they are ugly things, at the same time i dont want to do something that may be considered bodged together.
Really i would like to put proper wall plates in for each connector, but i have not been able to find the wall plates. There is a company in the USA that does them, but because they would be custom to fit all the sockets i need, they would want nearly £100, without cables, once ive baught the cables as i would need more using wallplates, its nearly the price of the TV so its not really viaable finically.
What i plan on doing is running some conduit in the wall, as its not mains cables, i dont belive they need to be shielded, but i want to check, i will be running confuit for ease of changing cables later, but i want to use the right stuff for the job. I was thinking that just capping it with some steel capping would sufice as there is nothing that would carry any sort of current, or voltage (just AV cables) Does anyone know if i can correct with this thinking?
I will need to run a power cable for the TV, and i think i have a few choices, i want to know which would be best, as i can see advangages and disadvantages of each.
1. Put the TV power cable inside the conduit with the other cables, and plug it into the socket as you would normally when it comes out the other End (Advantage: Very Very Easy - Disadvantage: not sure if its safe)
2. Add a socket into the ringmain that is located behind the TV (Advantage
robably the Best- Disadvantage: Not sure if i would have to have someone inspect the work)
3. Add a Spur socket from the ringmain that is located near the TV and run it upto the TV.
(Advantage:Fairly easy, but more effort Disadvantage: Not sure if i would have to have someone inspect the work)
4. Add a fused Spur that goes stright to the TV
(Advantage: Easy - Disadvantage: not sure if its legal)
So my questions....
Has anyone done this before that can offer some advice?
Is there anything wrong with the way i want to run the AV cables?
What would the best thing to do with regards to the electrics?
Just for reference, i am not qualified at all, I have helped my stepfarther who was qalified (no longer my stepfather) Install Lights, extra sockets, Celing Fans, and helped him mount his TV (he used the same method and Added a Supr in for the powersocket).
Thanks for any advice, im sure i will have more questions as i go round the house, my main worry isnt if it is doable, but if it is legal.
So my questions....
