I have a track that leads to my and 5 other's houses.
The track is approximatly ~150 feet long with the houses evenly spaced along the track on both sides and we would like to add lights to it.
My 'problem' has 3 layers of possible complexity:
(1) I would like to install sensor lighting so that will illuminate the wholetrack but can be triggered from 3 points along the track. (A movement sensor is no good for the person at the top of the track if they have to walk to the bottom of the track to activate it !)
(2) If (1) is possible then what about this. Is it possible to have 2 lights at each point, 1 pointing up the track and 1 pointing down and ONLY trigger the lights that are pointing in the direction you are travelling. (I think the solution to this may involve 2 sensors at each node, pointing in different directions and connected to 2 different circuits. When one is activated the light shines on the other's sensor thereby deactivating it - any other suggestions?)
(3) Is it possible to expand on (2) and have JUST the lights that are required light up rather than the whole track turning on when triggered.
Solution (3) would result in the people at the bottom of the track having lights shine their way pointing only in the direction of travel ('out' or 'home') and lighting only the bottom part of the track. The people at the top would have the whole track lit up when they left home in the dark and on their return home the lights would turn on as they progressed up the track.
Please offer solutions to any of (1),(2) or (3)
Christopher
Christopher
