Hi guys, hope someone (or all!) can help!
I've been asked by a mate to give him a hand moving his bathroomand making a small ensuite. I dont normally get involved with the waste side of things so we wanted to run the general ideas past you for vetting...
Below are a couple of pics to give you an idea of the situation.
First is the current view of outside Soil.
View media item 12001
This one shows the proposed layout from above (on left) and the view as it would be from outside (on right).
View media item 11999Hope the second is clear?
basically the soil pipe runs from the toilet out to join existing stack below current soil pipe from another wc, joined onto this via a boss section would be a 50mm/2" pipe which drains the bath and 2 back to back basins either side of a stud wall. Further down the soil branch will be a 40mm/1-1/2" pipe via a strap on boss, which drains the shower tray.
All the pipe runs will be within those given in Approved Doc H1 (drainage), which would suggest that we don't need any further branch ventilation (to avoid any trap siphonage), the main stack is vented thru the eaves above the roof level.
Does anyone think we will still need to vent the main soil branch outside (shown on diagram) with an AAV/durgo (dont want to go with normal open vent since would have to take pipe up roof (has loft conversion which we would have to go above).
Any and all comments/questions welcomed!!
cheers
cheers
