Hello all,
After some advice re my planned log burner install (which will be carried out by a Hetas fitter)
I have had three Hetas fitters round to quote me for the install, one stating that I cannot have a timber surround at all. The other two say I can.
Due to this I have been reading up myself and have been trying to clarify what I can actually install.
I have attached an image (not to scale) which shows all dimensions. The only combustible item is the timber surround which was originally in the house with an open fire.
The three walls of the chamber are all 12mm Hardie cement boards which have been dot and dabbed onto the original brick chimney chamber.
There are also 35mm slate slips surrounding the opening which bring the total depth of the chamber to 395mm.
Due to this is it possible to install a stove with a minimum distance of 300mm to combustibles at the sides? Baring in mind the stove sits within the non combustible chamber ?
Thank you In advance
