My new baby is coming home today and the heatings packed up
14 Feb 2004
:cry:
Help !!!!! My new baby is coming home from hospital today - and my heating system is doing strange things!!
We have a Baxi Solo boiler (VM 60/4 RS). When we put the system on the radiators and water seem to heat OK, but the boiler sounds like a kettle heating up and generally complains, and the header (?) tank in the loft heats up and starts to boil !!!
Any suggestions would be gratefully received.
You might have to wait a bit longer for a plumber to reply but in the mean time have you tried turning the boiler stat down if it's too high ? Does it settle down after a while ? Sounds like the water is overheating causing the water expansion back to the F & E tank.
ps:congratulation on the baby ! (don't name it Baxi after your boiler ;) )
sounds like the heat exchanger or stat. you might need a new stat they dont cost much for solos. The stat doesnt seem to be cutting off. by turning the stat to 1 or 2 would be the same as a new stat at 3 or 4. Try as the last perosn said turn it down but start thinking about a new stat before you loose the stat cut off completly
supply n fit around £98-00
