My rev23rf has lost connection with the Rev-R.03/1. I have tried all the things the manual tells me but still it will not connect. It was OK yesterday went to put heating on and it lost connection. Please help.
I assume you mean directly connected to the mains and not via another timer.
Did you check that all the time temperature settings have been retained?
Do the lights respond correctly when you follow the commissioning instructions to link the transmitter and receiver? If not, one of the components is faulty.
Commissioning Instructions Switch on power and press “RESET” button for about 4 seconds:
Orange LED_2 flashes briefly.
Then, press “SET” button for about 4 seconds:
Orange LED_2 flashes slowly;
learning mode is active.
Within 25 minutes press “ESC” button on REV23.03RF for about 4 seconds:
Orange LED_2 flashes fast and briefly;
LED_1 changes from red to flashing green.
After commissioning, the unit will operate automatically
If you have had the stat for less than one year, make a claim for replacement under the warranty; and if less than two years make the claim under the Sale of Goods Act.
