my toilet
4 Jan 2006
Newcastle upon Tyne
hiya, i think this is where this should go.
My toilet has only the minimum amount of water in the bowl, at time looking like it has none, has any-one any idea what it could be? i would be very grateful for suggestions or advice , thankyou in advance :D
your cat drank it :idea: ..................................or it got syphoned out -maybe a blockage down the sewer line ;)
A blocked vent stack, or partial blockage in soil pipe?
Something caught in the trap, and acting like a wick? (cue the marigolds, mirror on a stick and torch)
Is it on the ground floor or upstairs?
Is there a soil vent stack running up to roof level, or is there an air admittance valve on a short stack, probably in the room as the toilet?
If it is on the ground floor, it may not need a vent as the stack is relatively short, but a partial blockage downstream can draw water out of the pan.
funnily enough..ive just installed a brand new bathroom suite in my bathroom.....ive got one of them half flush, full flush toilets....even the water in there, in the bowl doesnt seem to be full ....it sems a lot less then the old toilet i had......mind you this new toilet flushes in a whirlpool kind of action...i think they are designed to use less water and flush this way...hope this helps
The water seal couldn't be drawn out unless there's a blocked or missing vent.
