Hi
Got the above gas hob - actual model number T26F66NO
We cannot use the gas hob as the on/off button and spring have both popped out. The bottom of the button looks possible sheared off so assuming it should be connected to another plastic part which then touches a circuit board.
Is it difficult to replace ? Im struggling to find the part number i need. Looking under the hob the green circuit board is still attached to a cable but the board is loose. Should this normally be attached to the bottom of the button assembly.
Can i bypass the on/off button to still use the gas ?
What parts do i need.
Thanks all
Regards
Gaz
Thanks all
Regards
Gaz
