I have spend a few hours reading about various issues relating to this, but can't find one that suits my issue. Here we go.
I had an 8.5kw wickes own brand shower ( made by Triton). 2 months ago i had my bathroom refitted & a new 8.5kw(Triton) shower installed. This worked fine until the weekend, since then it keeps tripping the RCD. My set up as below.
Cable from main fuse board (30a fuse) nothing else connected to this fuse ( say 3m of cable) into a switch on the wall outside bathroom. Then a cable from this switch ( again 3m ish) into the new shower, cable is around 6/7mm.
After reading the forum i am lead to believe the fuse should be rated @ 32A ?? But why is this problem only happening now, the old shower (same Kw) we had for 3 yrs without any issues.
We also have a fuse for the cooker rated 30A (i swapped these over) this didn't solve the problem.
Really need to know if this is a shower issue so i can call Triton or an electrics issue which would mean i call an electrician??
Thanks in advance
Westie.
Thanks in advance
Westie.
