Must have been when I was taking a break from the forum because I always flush new systems with X300 or F3.
Double panel Radiators - are they all same quality as he will buy them. Do I insist that he buys from the likes of Wicks and B&Q, to maintain quality as he might source them God knows where?
Not really much point dictating the source of the rads, better to specify by quality brands if you're worried - although I think you are worrying unnecessarily. Myson and Stelrad make good rads, but your plumber will be repricing the job. Upwards!
The really important part is to ensure that the system is properly flushed out, not power flushed, after installation. Then a corrosion inhibitor is added to the system. You need to maintain the correct concentration of this inhibitor in the system in future. This is the best way to ensure long life of rads, etc.
At least you won't have any worries with your choice of boiler.
Thanks for the reply.![]()
We're installing a new heating system with a combi boiler and new 22mm pipings and replacing all old rads, does the system still need to be flushed? This corrosion inhibitor, is that essential? I asked him about fitting a filter, he replied that these are extra and not usually essential![]()
F3 is a sludge remover and not for use on new systems!
Fernox said:Neutral universal cleaner for pre-commissioning new systems in accordance with BS7593:2006
Cold flush then a hot flush, no need for chemicals on a new installation, just a gimmick to sell product, ensure that the system is designed well at that de-aeration is adequate, no air, no corrosion its that simple
Silverback, are you saying no need to add inhibitor, just flush the system?
No he only means that its not necessary to use X300 on a new system! Just like all the other installers said.
As he was Installer of the Year in 200X then you have to at least note what he says.
However, the British Standards say that a cleanser should be used! So I use a cleanser and nothing better in my opinion than X300.
