I had a new Remeha combi boiler fitted last week. Everything
is fine with hot water and heating except now the Aqualisa thermostatic
shower valve only runs warm even when set to max temperature
(whereas the hot water taps give piping hot water). Something
else to note (which may not be related) is that it is now very difficult
to turn the handle of the shower to the On position. Combi pressure set
to 1 bar and pressure of hot and cold is even from the taps.
Before the combi I had a gravity fed system with pumped supply
of hot and cold from tanks. Shower gave piping hot water then,
although admittedly I would always turn it to max temperature
Any ideas on the cause of this would be appreciated.
Ben
Ben
