Hello all,
I just bought a new Indesit cooker (built under) and I am uncertain how to wire it in the cooker is rated at 5.2KW it has a double oven and grill. The instructions show wiring it with the hob but I have a gas hob which is wired seperately, so I need to wire it on its own. I have a spare trip on my CU which was used for an old cooker (rated 40 amp not used fo 5 years) I would like to use this as the old oven used to trip the 15amp breaker on the old ring when using too many appliances. The instruction show a double pole switch and 4mm cable is this correct as I cant find 4mm cable only 6mm or 10mm also what size breaker do I need (the unit is a Wylex NN )
