new decking what treatment?
6 Apr 2008
Yorkshire
just put down new decking do i need to stain or oil it to make it last.
thanks
Did you use pressure treated timber?
Did you treat the cut ends?
In either case there are a number of decking treatments on the market you could use, ronseal, cuprinol etc even thompsons waterseal can be used on wood, and is clear if you like the wood colour.
thanks for reply
it is tanalised treated rosewood
but i did not treat the cuts
would advise treating any cut end grain. if you look through the cross section where cut you should be able to see the depth the treatment has soaked in.
B&Q do pots of end grain preserver for a couple of quid - (intestingly enough i couldnt find any at my timber merchants?!?
