Hi first post so go easy on me guys/gals
Would like a little advice on fitting a hob and double electric built under oven.
I have seen an electric ceramic hob which is 6,700kw and the double oven is 4,600kw making a combined total of 11,300kw.
Consumer unit is 32amps for the cooker circuit .
I was thinking of connecting them both with a dual click plate as both would be in the 2m distance to CCU.
Now manufacturer states HO5RRF-3G or equivalent for the hob ( i am guessing this is just heat resistance flex) ?
The manufacturer for the double oven states to use HO5VV-FG3 X 2.5MM2 or equivalent ( again i guess heat resistant flex)?
Now the total amperage would be roughly 49.130 amps at 230v , but applying diversity it would come to 21.739 amps.
Would it be ok to use this http://www.tlc-direct.co.uk/Main_Index/Cable_Index/Flex_Butyl/index.html
4.0mm 3 core - Buytl Heat Resistant Cable for both appliances connected using the click 45 dual outlet plate ?
I know for the oven i could get away with 2.5mm 3 Core - Buytl Heat Resistant Cable ,but thought it might be better just using same cabling (4.mm) for both .
Or would you guys use 6mm T&E as it would be a lot cheaper and still work or stick with the above ? What do you guys reckon do i really need to use heat resistance cable as most people seem to use T&E ?
Going out to buy them once i know this is ok.
Cheers ..And all the best.
