We have a house, built in 1974. The plans were for a fireplace, but it was cancelled in the last stages of house construction and bricked over. The chimney/flue were fitted and builder's space constructed, then it was bricked over.
Nearly 40 years on, we have decided to open it up for a real wood fire, purely for atmosphere.
We have found the builders space and it all appears to be in good nick. So far we have just opened one brick and inspected it. The space itself measures approx 700mm wide by 940mm high, 370mm deep with a clean, lined flue.
We are fairly competent DIYers, but this is new territory. I've spoken to the Local Authority (building) and they said they consider it opening up an existing fire, so don't really care. Also have a sweep on standby to come and check once we open the space up completely.
We have been researching fireplaces (mantels, surrounds, hearths) purely from a decorate point of view, and also getting up to speed on fitting of a fireback.
Now then, firebacks seem to come in 16" (406mm) or 18" (457mm) standard widths, whereas we have a 700mm wide space (or will do once we open it, which I'm not doing until we have a lintel in place). I'm fine with everything I can find about backfilling with vermiculite/cement mix, cardboard to create an expansion space, etc. and building up from the back to a slope to meet the entrance to the flue.
What about the sides, inside the builders space? The flue entrance is off to the left. If I position the fireback in the centre, do I then just backfill both sides as well, and slope them down into the fire? Trying to figure out how that works to the right, as I will have a slope going away from the centre, but to a sharp angle top right...?
