Hi all,
ok, i'm a non-pro diyer, but have done plenty.
New kitchen going in soon, after all prep work.
I need to re-do all the piping from where the mains enters the kitchen. It need to feed the sink mixer taps, dishwasher, washing machine, tee off to an outside tap (through the wall obviously) and also the fridge/freezer.
I've done a diagram of how it will all work and shouldn't be an issue.
So, PVC is much cheaper than copper at the moment (i think).
Do the PVC isolators have a reduced bore and would this impede supplying a full size dishwasher and washing machine. (some wm's have water pressure sensors don't they?).
If not, then i think PVC may be the way to go for the whole job. No point mixing and matching. Plus the isolators have turnable taps (not slotted screwheads that are fiddly)
Also, is there a discernible difference between the white pcv stuff and the grey? I've learned from experience not to mix the two, unless you have the correct inserts for each (metal for grey, white plastic for white).
Thanks for any advice offered.
