Hello all. New to forum. Installed a new laminate floor about 3 weeks ago and ever since it's been laid, when I walk across it, I hear a cracking sound in spots. Mainly in the hallway. It's beginning to drive me nuts. It's a 7mm laminate floor, uniclic design. It almost seems as if the joins are flexing and causing the sound. Like a cracking or clicking sound. Will this go away? Is something wrong?
Thanks,
Nitemare.
Hi' that sounds terrible, after all the work laying it. The place I have just moved from had laminate flooring put down over 5 years ago and honestly it never made a sound when anyone walked over it. Did you make sure every single floor board was nailed down tight, IF you laid it on floor boards. Also did you leave the correct expansion gap all round for movement. At least 10mm. The other thing that comes to mind, if you used just a 2mm underlay, which isn't really thick enough to absorb any real flutuations in the floor. Did you check that the floor was nice and even all over with nothing sticking up. I hope your annoying noises disappear in time, I know it would drive me crazy. By the way, it's
not natural for it to happen.
