New Radiator[/b]
17 Oct 2005
Renfrewshire
Hi Guys,
I've just fitted a small radiator in the utility room. The easy option is to feed off the radiator in the toilet next door. (10mm micro bore.) Is this okay?
Much Appreciated..
But seriously, it'd be impossible to tell, without knowing things such as what power is the rad in the toilet, what power is the rad in the utility room, does that run of 10mm feed anything else?
easiest way of finding out would probably be to hook it up and see if they both get hot enough.
