Hi all,
I've just installed a new radiator in a house we've just moved into, and it's a lot cooler than ALL the others in the house, downstairs and upstairs. The others are quite hot to the touch and cannot touch for too long.
Apparently there used to be a radiator in the this room years ago, but the previous owners had it removed so that they could fit in a bit cabinet. They just cut and capped the pipes and so when installing the new one i just used the existing pipes. Had to do a bit of work to re-route them to the new, smaller, radiator, but nothing significant.
Anyway, got it all up and running but the radiator only gets lukewarm. Not sure why. System is clear (powerflushed by previous owners not too long ago), and all other Rads piping hot. The new Rad is downstairs, the boiler is downstairs, the pump is upstairs.
I originally put in a TRV, but I had a bad experience with one years ago, so decided then to replace it with a normal valve. This did improve things slightly, but not really enough.
I now can't decide whether the system needs balancing, or whether there's another fault. Anyone help?
Oh, just one more thing, the flow pipe and the valve are absolutely boiling to the touch, but all of the radiator, and return pipe, is luke warm. Can't understand why it's so hot at the valve but not that hot in the rad, even at the end with the hot valve!
Any advise would be appreciated.
Thanks,
Andy.
Thanks,
Andy.
