having just looked at all that, and if the service fuse is only 60A surely its a fluke that i have not been having problems already?colport27 said:Service fuse is possibly only 60A, just to add to the confusion.
na, its a two bed flat, with a grand total of 13 sockets.crafty1289 said:You should be Ok with that setup.
I was concerned you had a house with 3 ringmains and an electric cooker etc. In which case that box would be unsuitable.
scottfc said:having just looked at all that, and if the service fuse is only 60A surely its a fluke that i have not been having problems already?colport27 said:Service fuse is possibly only 60A, just to add to the confusion.
andy said:my house only has a 40A fuse (ive had it out before, has no seals). and it survives with a 9.5KW shower aswell as other loads. + electric cooker. almost 10 years down the line and no problem...
crafty1289 said:andy said:my house only has a 40A fuse (ive had it out before, has no seals). and it survives with a 9.5KW shower aswell as other loads. + electric cooker. almost 10 years down the line and no problem...
Why not change it for a bigger one while you had it out?
crafty1289 said:now the opposite . . . where i work, there is a 3ph 100A incoming supply (only installed 3 years ago), and the main breaker for the whole shop is a C63
you tell me?? its a 3-phase C63 as the main switch of about a 6 to 8-way 3ph board. This board got full a few months ago, so they decided to add on another board using another C63 in the original DB.andy said:crafty1289 said:now the opposite . . . where i work, there is a 3ph 100A incoming supply (only installed 3 years ago), and the main breaker for the whole shop is a C63
er... why is the main incomer a MCB?
