No DHW - Worcester Greenstar 24 Junior
14 Jan 2005
Glamorgan
Hi All,
My son's combi is not producing any domestic hot water, but the central heating is working ok.
I remember when my old combi had a similar problem, it would generate hot water if the central heating burner was on. But in this case it is not having any effect. I assume that the modern combi manages the cold water feed somewhat differently.
Water pressure from the hot tap is ok, so I think there is a sensor/valve fault somewhere. I would be grateful for any pointers.
Cheers
Doug
Fixed it by tapping a valve. I will keep an eye on it as no doubt it will have to be replaced if it recurs.
