No electric to property at all ?
If you call the local emergency power loss phone number they will tell you if there is a power cut in your area
Why not call them now they will come out ASAP and doesn't cost you
I can't see an earth wire from the service head. Are you sure there isn't another RCD somewhere before the consumer unit if you have an Earth Rod?
Flats?
Is there a remote distribution board serving these flats?
If you have removed the main fuse and have multi-meter, try a continuity reading across it, this will prove whether it's down to the fuse at your board.
There might be a ryefield unit as the supply looks quite new.
I'm not going to say too much though as I don't want to encourage DIY tinkering with DNO equipment.
First thing to do is check the wiring at the isolator and check the isolator it's self too.
