I've recently had a new kitchen and extension completed on my house and since the works been completed I've lost all my heating and hot water.
It's a Y plan system that i used to switch off and on (for heating) using the thermostat in the lounge, only because the programmer is buried at the back of the airing cupboard and hard to get to.
When i call for heat, the boiler in the kitchen would fire up and off we go. Now I do it and nothing. There's no hot water either and the pump in the airing cupboard isn't working, although there's power to it. All wiring in the airing cupboard seems to be correct.
When the building work was done, the boiler itself wasn't moved, but the fuse box was relocated and from the hallwall to the kitchen and the gas inlet pipe was relocated. There were 2 different electricians on the job, one who moved the box and another did the electricity for the kitchen, but each one says they havent touched anything that would effect the heating system and aren't interested in coming back to take a look. During the work, one radiator was also removed and the pipes capped off.
I'm out of ideas as to where the fault might be, does anyone have any ideas?
The system consists of:
Honeywell ST7000 programmer
Danfoss room thermostat
Thorn EMI Olympic 38/50B Boiler
Honeywell V4037A 3 port valve
Flowmasta 25-5-130 pump
Any help would be greatly appreciated!
