Could someone please advise me.
I recently purchased a property that is in need of some work.
I am about to fit a new kitchen but the kitchen window is in need of some TLC based on the fact that there are cracks in the brickwork and what appears to be a couple of bits of old wood inside, holding up the inside wall. I intend to drop the window a couple of courses whilst I am sorting it out as the cill is a bit too high.
I note elsewhere around the house that all the other windows have a soldier course above so I would also like to do the same here.
My thinking is that a catnic lintel which will span the outside AND inside would be the correct course of action here. Would you agree?
My plan is to knock out the two badly matched (And badly fitted) bricks (which were very likely put in place to fill the hole left when the Ventaxia was removed) and slide a 5' bit of 8x2 hardwood in and support that with an accro outside & in.
Then remove the window, take out the two courses below and then install the window. Then place the lintel above (with around 150mm either side) and build the soldier course on top of that. Then lay the courses above and then repoint the gaps.
If so, will weep vents be required above. The place is rockwool insulated. If so how far apart and would a couple of holes in the mortar be sufficient?
Another thought is that I should pemove the mortar from the cracks FIRST and repoint then and THEN fit the window.
Which would be correct?
Window is 1350 x 950.
I included the last photo to show the bad join in the brickwork where the house was extended. (Originally a chalet)
