My first post, hoping for some advice.
combi boiler Ferroli 77FF req to be topped up on regular basis.other problem is the boiler makes what i can only describe as a \\\"grinding noise\\\" on occasions,this when the CH is on,if i then turn on the hot water tap the noise stops and then starts as soon as tap turned off. I\\\'ve noticed that the pipe outside is getting some drips.If i then top the boiler up its ok for a few days then i get the grinding again when it runs alittle low.
Hope i\\\'ve made clear what the problem is, any comments or advice much appreciated,thanks in anticipation
