Non start micra 2004
28 Nov 2015
hi everyone,
My Nissan micra k12 does not start or turn engine, I can open doors with fob, also when I turn the key all lights show on dash, after second ps light abs light n other they go off normally the but NATS light stays on does not go off, was told ecu if faulty but it's wrong as I have tried to swop complete ecu kit but the problem is still the same. Help plz if any on in London can solve don't mind paying him
Im assuming you disconnected the battery to carry out the work?
If not try disconnecting it for 15 mins or so to see if it resets the system.
Hi thanks for the reply , I did all did disconnect the battery before fitting the whole kit, also kept the key on position for half an hour did as read n forums did also did charged the current by connecting positive and negative cables but nothing, I don't know if the main fuse box under the light is coded with immobiliser or not as lights wiper even the fuel pump relay is working but it does not crank power on main cable from starter motor is there the Bly ready f starter motor relay does not get power which I don't know if it's getting power from immobiliser?
Help
