I'm replacing two radiators as they've seen better days (thick with paint etc) However they're an odd size - 640 and 790 wide. Measuring centre to centre of the pipe gives 700 and 850 (ish) respectively. I say ish as the pipes are old and not exactly true.
I was considering adding valve extensions to a 600 radiator, but unsure about the 790 as I'd need to either go with a 700 and large extensions, or probably more sensible and possible, bend the pipe out by 10mm overall.
Any suggestions?
Any suggestions?
