I have a new conservatory and have been told that oil filled radiator is the best and most economical way to heat it. Can anyone tell me which is a good one? It's a 12' x 12' room.
Oil filled radiators are usually fairly low powered & only any use in taking the chill off a room. Heating a conservatory will never be economical with all the glass involved. The only decent way to do it is extend your central heating into the conservatory, if it is feasible(in my opinion, for what it is worth).
As I said, oil filled radiators are only really suitable for background heating, if you do not have any other option to using electric heating & require a good heat source then I would not recommend any type of oil filled radiator. It depends on the size & shape of your conservatory but I would have thought if you want to heat it to a comfortable level to use it through the winter months you would need at least 2 x 2KW panel heaters (for the average sized conservatory). Do a google search for panel heaters or electric heaters, the options are endless, but you have to decide what your requirements are & calculate the energy needed to heat to a temperature, for your particular conservatory.
