I'm replacing the oil line on my central heating system. I have 10mm copper pipe currently from the boiler to the tank. The pipe comes out of the boiler into the space under the suspended floor in my utility room (cannot lift flooring) and then out into my garden. I propose to cut the oil line and join it to new 10mm copper pipe as the new tank will be located a bit further away than it is currently located. The joint will be under decking eventually, with access to it from the side possible.
My problem is that I was going to join it by solder-ring fitting, but have read that many have had to use flared fittings.
The consensus elsewhere in this forum is that compresstion fittings will not be adequate due to possible leaks.
Any help will be welcome as I don't want to fall foul of any regulations I am unaware of.
