I realise most electricians are incapable of thinking for themselves
That is just not true. The majority of sparks (I am not one) on this forum will give you good sound advice.
It's just that a few (a small minority) (mostly one) don't know any beter.
No we are going backwards, the 14th edition also stated that 3 phase colours as red, yellow and blue. ie primary colours from different areas of the spectrum. Almost totally impossible to confuse one with the other.
The IET now tell us that these colours have to be brown, black and grey.
Nothing wrong with fixing cable to a fence as long as fence is rigidly built and firmly fixed. But I would feed the cable via an 30mA rcd.
Someone earlier in the thread mentioned leaving loops in the cable, they are mad.
Nor was I impolite, as Johnmelad confirms by his inability to justify the allegation he made.BAS is not an electrician.
"Usually", eh? how common do you think instances of impoliteness should be for it to be reasonable to say that it is "usual"?But you usually are,
But in this case you don't have to use any "law of averages" - the post is right here for you to use to justify your accusation.so by the law of averages you probably were.
What's impolite about that?Then pay someone else to dig it. Simples.
What's impolite about that?Not really.
What's impolite about that?No, because it's too cr*p.
What's impolite about that?Yes - do it properly or not at all.
Nor was I impolite,
But you usually are, so by the law of averages you probably were.
I would say that you must have a very odd idea of which words are rude, and which are not.I would say that 99.9% of second or third replies by BAS have some/a lot/quite a lot of rudeness and aggression in them. By the time he gets to a fourth reply he is 100% rude.
1) I've never said that they are all liars, only that they cannot be trusted to tell the truth.Who else on this forum can get away with suggesting that all plumbers are lier's?
I may have said they all are, but I don't remember doing so - could you refresh my memory on where I did, please?Who else can get away with referring to all users of the General Discussion Forum as: "dribbling Neanderthals."
