If it works with the head removed then the head is faulty,not the valve
Most heads are NOT interchangeable
Some same make heads do fit other same make valves
Usually there is very little price between a replacement head and a complete valve,so probably best get new complete valve and just swap the heads
On some heads,you can screw in the part that operates the valvepin,but you wont get accurate readings
Make and model/picture helps lots
