sorry, i mean't second post..
Thats what I thought, so is underneath a wall cupboard 'clearly visible' ??
Depends exactly how you do it, my rule would be, would a stranger know how to turn off the appliance?
When would a stranger ever need to do such a thing? If
If its not obvious its not acceptable,
a bit of conjecture here, this is your opinion.
heres what the applicable regs say.
537.2.2.6 Each device used for isolation shall be clearly identified by position or durable marking to indicate the installation or circuit it isolates.
position
OR durable marking. So i could position it in an adjacent cupboard and mark it 'cooker'. Therefore a switch in a cupboard can comply with 537.2.2.6
Also section 537.3 "switching off for mechanical maintence" may or may not apply.
IMO, the most likely reason for a designer to include a n isolator. A consideration of convienience for the user of the installation. However, theres nothing in section 537.3.2 which precludes installing a switch in a cupboard
There are regs that deal with remote isolation, these call for instructive labelling and lockable isolators.
I take it you are referring to 537.3.1.2, thats valid for remote isolation, but we are talking about a cupboard adjacent to the cooker, which would be continuously under the control of the person carrying out the maintenance/cleaning. If there are more regs you are referring to , please advise.
Edit - forgot this one - 132.15 "Isolation and switching" - 132.15.1 Effective means, suitably placed for ready operation, shall be provided so that all voltage may be cut off from every installation, from every circuit thereof and from all equipment, as may be necessary to prevent or remove danger.
'suitably placed' doesn't preclude being in an adjacent cupboard.
In general terms, If the intended purpose of fitting a control switch or isolator was for emergency switching, i would recommend that the switch be fitted somewhere obvious.
However, due to 537.4.2.6, i don't think cooker isolators comply with this where the cooker itself has manual control switches. Therefore, in the majority of cases, cooker control switches should not be considered as 'devices for emergency switching' so they don't have to be placed somewhere obvious, merely somewhere convient for their intended purpose (switching off for mech. maintenance)
Also, if as you suggest, you are not talking about emergency switching specifically, just switching in general, then why is it you cannot fit a cooker switch in a cupboard, but you can fit an immersion FCU or a CU in a cupboard? Thats a bit inconsistent.
