It Is not connected to a 13Amp socket it is via dual pole 20Amp switch
on its own circuit back to the main board protected by a 16Amp MCB?
It Is the cabal from the 20Amp switch Thit is going a bit Black Do you think It could be the 20amp socket that is at fault. Sorry about the picture but ihave only been told about It By my Daughter
Have just had an email from my son in law and he wants me to go and get a new element.I think he is wrong but if that is what he wants Thanks for your help
What is the size and type of cable that is going from the switch back to the main board. As a minimum it should 1.5mm T&E but better 2.5mm T&E - grey cable.
If the cable is the correct size then it is possible that you have a loose connection at the switch and this is causing the problem with the cable.
With the power off - open the switch and check that all the conductors in the terminals are undamaged (not burnt or broken) and not loose.
If they are burnt or broken then you will have strip back the insulation until you get clean copper and reconnect the conductors in the appropriate terminal.
