Hi guys,
I have a small piece of wall, 2.3m high x 0.7m wide. It’s solid block with PB dot and dabbed to it. Between the block and the pb is some 10mm microbore pipes for the radiator. I had to cut some of the pb away at the bottom to relocate the radiator and in doing so used 15mm copper pipe. So it goes up from 10mm to 15mm. Anyway obviously I can’t patch up this bottom bit as the pipe is now deeper than before. I wasn’t initially that concerned as I thought I would just overboard over the top and use some sort of grab adhesive. The board behind is fine apart from my cutting away a piece at the bottom.
Is this ok? Or is it a total bodge? I know I’ve got some pink grip, some green grip and some no more nails turbo kicking about somewhere. Is any of this suitable for sticking the new board to the old board?
cheers!!
cheers!!
