I don't know - I've not done a risk assessment.So I really do wonder what the risks of a live armored 3c 6mm2 cable supported on a catenery over a path actually are?
Perhaps BAS could educate us
If it's only foot traffic under the cable, don't worry about it.
So what will be the lowest point of the curve the cable will adopt? Id it actually runs through the bushes what about the frequent movement in the wind?The problem i am having is the garage itsself is only 2.5m high and my mate doesnt really want a pole coming up from his garage to meet the 3.5m height requirement altho the point i exit the house is just over 3m.
The distance from the where i plan to exit the house to the point i enter the garage is 3-4meters.
Is that the best way to supply an outbuilding?Mainly because theres a spare 32a in the DB
And is the availability of a space in the house CU the right factor to use as the most important one in the design?
It is, but the question is should you come off the house CU at all?I wasnt meaning to sound so lackadaisical about the mcb i was mainly thinking that a 32a mcd which is rcd protected will be ok to protect a 6mm SWA to supply splitter with 16a and a 6a mcb's.
Meter tails into a switchfuse to supply the garage would be my preference.As i said this is my first time doing this sort of install if you have any pointers i would welcome them.
If you're in the garage and the RCD trips, you have to schlep back to the house to reset it. If anything goes faulty with the cable or the installation in the garage you'll lose the house circuits on that RCD until the problem is fixed.
Is your mate going to get a fridge/freezer that is specifically designed for use in 'outhouses'? The great majority of those around warn that they are not suitable for use in outhouses since, ironically, they can stop working if the ambient temperature gets too low.I had discussed this with my mate but he is happy with that as unfortunatly he wants to keep costs down, plus it will be his main fridge freezer for his house as he has no space in his small kitchen for a big fridge freezer so it might actually be best so if it trips he will know about it and it could save all his food.
You say that every time I make that comment, so there's probably not much to be gained by repeating it. It may be totally logical to those who understand how refrigeration works but I reckon that the great majority of people would regard it as ironic that a device designed to keep things cool/cold should stop working if the surroundings get too cool!It's not ironic.
Then stop repeating the comment that it is ironic.You say that every time I make that comment, so there's probably not much to be gained by repeating it.It's not ironic.
Maybe they would, but falsely regarding something as ironic because of ignorance doesn't actually make it ironic.It may be totally logical to those who understand how refrigeration works but I reckon that the great majority of people would regard it as ironic that a device designed to keep things cool/cold should stop working if the surroundings get too cool!
You're obviously having a quiet day! Whatever, I'm not so sure about that. AFAIAA something is 'ironic' to someone if it differs from what they expected, and I think that probably remains true even if their expectation is actually incorrect. I'll leave you to debate the dictionary definitions.... falsely regarding something as ironic because of ignorance doesn't actually make it ironic.
Kind Regards, John
You're welcome - and, yes, I think he should be made aware of that, whether or not he regards it as "ironic" that a fridge/freezer can stop working if the surroundings get too coldI wasnt aware of that, i'll let him know thanks for that!
