Maybe he needs the increase in breaker capacity for the 20 downlights and the security light he fitted
Maybe he does. But will he then also change all the items on the ciruit to ones that are rated at 10 amps ?Maybe he needs the increase in breaker capacity for the 20 downlights and the security light he fitted
It might if there is a fault in the light it is controlling.no switch will see 6A, let alone 10.
Unless it's a unit with a fixed busbar.Undo all mcb's on the same buzz bar via the lower screws at the switch and at all mcb's.
The buzz bar should now drop out
