I painted the whole of my houses exterior walls last year (May / June). The house was built in 1832 and has quite thick solid masonry walls with an exterior render which is painted white. The house has very limited / no ventilation i.e. opening windows, wall vents etc. and therefore naturally breathes (or so I'm told).
The house was un-occupied for 2-3 years prior to us moving in and subsequently damp was present in some rooms! I painted the house exterior after approx. 15 months of moving in.
I cleaned off the old flaking paint the best I could and applied 2 coats of a water based masonry paint (nothing particualr fancy, Wickes own brand I think). Following avery cold winter in 2010-11, I noticed in Jan 11 that the paint had blown in certain areas with large sections falling away / blowing off in the wind. It is mainly the lower sections of the wall which has flaked off - the upper section is partially protected as the roof over hangs by approx. 1.0m.
I was planning re-painting the walls but am not sure on the best course of action (preparation, products etc.) Does anybody have any advice for a novice painter? Thanks
