I want to permanently remove a radiator and cap off the pipe work below floor level so it is no longer visible when I put in a new floor.
The rad is on 10mm micro bore pipe set in a concrete floor
Is it just a case of digging out the floor around the pipes, cutting the pipes back below floor level, fitting some blank caps, add insulation, refill and test for leaks, back fill with screed
The only things i wanted to find out were:
- What depth should i cut back the pipe work to below floor level
- Should i use compression blank caps or soldered ones?
