Bearing in mind that I am a novice in these matters I wondered if someone could be so kind as to give their oppinion on the following problem;
As far as I understand I have a gravity fed hot water system and a pumped central heating system. The boiler is a "Baxi Bermuda 5174E back boiler feeding to radiators through a microbore system. I am led to believe that there will be a manifold somewhere but I'm damned if I can find it! The problem is (and always has been in the 3 years I have lived in the property) air in the system that I am unable to bleed out through the rads. At times I can hear air in the back boiler when the CH is off but hot water is being called for. I have had the pump changed and this made a degree of improvement as far as the noise is concerned but there is still an obviously large degree of air in the system somewhere.
Is there a bleed valve on the mysterious manifold (any ideas where it could be?) or am I missing some other option?
Any help/suggestions would be gratefully received!!
