Hi guy's,
Posted recently about a problem with our Swiftflow 120, HW not getting very hot unless you backed off the tap to about 1/2 flow, then it took an age to run a bath!
Shortly after this, the boiler failed to light up at all, although the pilot light remained lit. The Glow worm engineer came and replaced a pcb, all seemed to be fine, and this also seemed to cure the problem with the hot water. Marvellous!!
Now, we seem to have a problem that when the CH and HW are run together (mainly the bath tap), the pilot light goes out when the boiler cuts out.
Could this be related to the changing of the pcb?
Many Thanks
Many Thanks
