My CH system is 3 years old, when installed it was installed in an unheated outhouse, hence (presumably) the pipe and frost stat in there with it.
I have now remodeled the kitchen, removing the partition wall between the outhouse and kitchen to give a bigger kitchen.
now that the boiler is inside, does it need the frost or pipe stat? the pipes that it is attached to will be inside a stud wall.
Personally, I can't see the need for them now its in the heated house, but im not a CH engineer.
Forgot to ask the engineer when he serviced it, did check about flue distances from the window though (its fine)
