In a scenario when I would usually use 15mm copper pipe, what size plastic pipe should I use?
Obviously 15mm plastic with an insert added, is going to have a smaller internal diameter (at the joint, but it will still restrict flow) than 15mm copper with no insert.
By that logic I should use 22mm plastic with insert where I would normally use 15mm copper?
