PIR Light
5 Feb 2005
Dyfed
When i double switch a pir light it stays on until
a) its switched again
b) dawn
if i double switched, say before I went on holiday, would the light come on at dusk every evening until I returned? Or would it reset itself after the first night?
thanks a lot
It will probably just reset the following day, tho not 100% sure, this is when you wish you hadn't thrown those instructions out :p
Can you not do a "dummy run " before you go on holiday and see what it does
It'll probably reset after dawn - and I doubt this is in the instructions.
What wattage is the PIR light?
150w - and you're right the instructions doesn't mention this. A customer wants to be able to have a normal pir controlled light but be able to switch it when he goes away so it comes on after dark. Not sure if the photocell overrides the pir.
charlie
