Just to throw another thought in .... our roof faces east-west (maybe slightly off this but close enough) - does that make solar even more debateable ?
Thee are no shortcomings. They are perfect for multi heat sources, of which you clearly didn't know. Most here should stick to drains.
Even YOU have shortcomings.
Sometimes you appear to be intelligent,
then you make posts like that.
There are no shortcomings. They are perfect for multi heat sources, of which you clearly didn't know. Most here should stick to drains.]
In which case, you are the perfect person to explain the advantages of a thermal store over a simple unvented to the OP.. He is asking for advise not sweeping statements.
Wow thanks for the replies folks - solar energy obviously stirs up some strong opinions! both for and against!
Solar is worth it if you DIY...and as fuel prices rise becoming even more worthwhile.
F
However tubes can be installed horizontally on a vertical south facing wall and are very efficient in that format.
Tony
F
Tony
But not in the winter.
Even on a DIY basis, a typical two panel collector system is going to cost £2000 to buy for the panels, pipework and controls
Tripe!!!!
Have you ever installed any solar panels?
Or even any gas boilers ?
Have you taken the Solar Assessments or even been on any manufacturer's solar courses??
yep. Even a whole solar roof.
stop being silly. I run rings around you.
Nope they are for the likes of you.
