Thought I'd create a new thread just in case the 'plastering over halogen spots' got lost in the ether (hope nobody minds?)
Basically the 2200 x 1800 sizes are going to be a royal pain to put up (having my girlfriend hold up one end whilst I drill holes and screw in the appropriate screws will be dam tricky).
Regards.
...Sorry to drag this thread from whence it came, but I'm about to finally start the ceiling/s (just about completing the house 'refurb' in the process.
Established the joists have 16" between each other and what appropriate plasteboard sizes I should use, but still have a couple of niggles (even though noseall kindly posted a great deal of help before I finally did his/her swede in!!):
1: The length of the boards should be placed at 90degrees to the joists above?
2: Would a joist usually be directly across the edge of the walls below?
3: *noseall Quote:
start from both ends, and put your cut in the middle. you should stagger the joints too.
I read this as 'brickwork' pattern as you would with laying floorboards?
4: I'm going to stuggle (my girlfriend will be helping) fitting massive boards into place - could I really get away with the smallest of boards (bit more expensive and little more wastage but far easier on first attempt to install). If I mesh tape then skim the joins these shouldn't show right....?
Muletide of thanks in advance!!
Regards.
