Plastic central heating pipes
16 Nov 2005
Hi all.
If you use 10mm micro bore plastic pipes and intend sinking them behind the plaster, do you need to protect them ?
Yeah i know silly question, its just that i was wondering if you just chase the wall, secure the pipe and plaster ? or do you fit conduit like when running wires ?
Conduit; also use plastic pipework in the conduit then it will be a doddle to pull out and replace in the case of any problem or rework.
