Has anyone plumbed in a pumped water system to a shower in plastic pipe & fittings? Will the plastic take the pressure and is there anything I should look out for. Thanks
Yes the plastic pipe and fittings will cope with the pressure. Make sure you use the correct inserts for the pipe you're using and that the pipe is pushed fully into the fitting. Make sure the joints are not stressed and that the pipe is clipped and supported adequately.
