I want to replace a sink and taps. I want to use flexis because the route is awkward. I have discovered that the hot feed is standard 15mm copper (which I am well used to playing with) but the cold feed is plastic. it looks a bit bigger than the 15mm copper and measuring it gives 55mm circumference which is about 17.5mm outer diameter. (The house was built early 70s if that gives any clues). A few local plumbing shops have failed to solve this. Can anyone tell me if I can get a coupler to couple the plastic to 50mm copper. If I can do so I can then do the whole job using standard flexis
