Not sure that's 100% correct, if you have PVC incoming water main and gas main, how does this earth all the pipework ???
What you have if you don't bond is a resistance of all pipework if not bonded, you then have Volts/Resistance = Amps (current will flow), should you touch both.
Also if not bonded and the pipework becomes live then touching anything earthed will allow current to flow.
