hi. some advice on positive pressure boilers pls
just wondering what you guys do if ur doing a landlords or service on say a neataheat 10/16 . the casing is always against the wall so you cant test with ldf if the seal is correct so im reluctant to remove casing as long as co reading and flame pic is ok. since i cant test the case integrity due to insufficient side clearences around boiler i simply put down NCS . is this correct. nearly every positive pressure case ithat ive removed has failed to seal back correctly thus having to cap off appliance. a corgi inspector told me to temporarily seal with silicone!! surely not??
